Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Should new tires go in the front or back? Discuss
Old 01-16-2013, 05:48 PM   #16
Julian@TireRack.com
Fan#: 102247
What I Drive: N/A
FF Reputation: 2 Julian@TireRack.com Good Standing Member
Put them in the rear. It's the same reason you should never install just 2 winter tires in the front of a front wheel drive car. If you start to slide taking a turn and the back end goes first because you have less tread ie. less grip, it's much harder to recover from the "spin". As compared to the front tires breaking loose and the car just pushes a little bit, this is much easier to control.
When we install tires here we will ONLY install them on the rear for liability reasons, and yes, there have been lawsuits over it. As for when we sell only 2 tires, we always put the following on the invoice....
Customer advised that mixing
tire types/sizes or new with
partially worn tires may cause
unpredictable handling,braking
or loss of vehicle control.
New tires should be installed
on the rear axle.
888-428-8355 ext. 4798
Remember to reference Julian/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Julian@TireRack.com is offline
