Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Intelligent Oil Life Monitor
Old 01-16-2013, 11:04 AM   #96
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 881, Level 15
Points: 881, Level: 15 Points: 881, Level: 15 Points: 881, Level: 15
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 6%
FF Reputation: 2 BrApple Good Standing Member
Originally Posted by VelociRacer View Post
Same here, message popped up while driving @ 10,250 miles. I cheated the computer by changing the oil at 1k and again at 4k. Oil changes and iOLM resets couldn't be easier.
Since car was built 06DEC11, the iOLM doen't appear to go by date.
Just waiting for the washer fluid to run out and see if a message appears. If not, TSB 12-4-13 will fix it.
So is it safe to say that if the monitor is working then it should active every 10,250 miles? I have not had the monitor activate, however I have changed the oil every 5k miles. I reset the monitor each time, except this last time. Since I last reset it at 10k it should activate just after 20k miles then?
Not sure if I need the TSB applied to my car. I know I need the washer fluid one done. Would be good to get both done at the same time.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
