Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Special Tool Required for Brake Master Cylinder Replacement?
Old 01-16-2013, 06:34 AM   #5
bennyfocus
bennyfocus's Avatar
Fan#: 50465
What I Drive: 2001 Blue Zx3
Points 1,348, Level 20
Points: 1,348, Level: 20 Points: 1,348, Level: 20 Points: 1,348, Level: 20
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 6 bennyfocus Good Standing Member
No sleepyboy is right, on some occasions you may need a scan tool capable of bleeding the abs out. Personally I have only ran into that issue once or twice. Also something else I think they listed as "special equipment" is a pressure bleeder, I think they prefer you pressurize the master then crack open the bleeders. As long as you bench bleed the master before you put it on then bleed the system like you normally would on any other car you should be fine.
bennyfocus is offline
