Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Special Tool Required for Brake Master Cylinder Replacement?
Old 01-16-2013, 06:02 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,454, Level 100
Points: 32,454, Level: 100 Points: 32,454, Level: 100 Points: 32,454, Level: 100
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
No, it's probably bench bleeding tubes. The master cylinder should come with directions on how to bench bleed it. You might also want a vacuum bleeder kit, but you should read the directions because bubbles in the lines on a vacuum bleeder are not a cause for alarm. It will actually pull air through the threads on the bleeder nipple.
Open up your new master cylinder and read the directions. Haynes Manuals are meant to confuse people and scare them into taking cars to a mechanic instead of actually giving customers technical knowledge of vehicles and systems. It makes the manual easier to write.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
