Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Flashing an instrument cluster
Old 01-15-2013, 11:21 PM   #4
Fan#: 108214
What I Drive: 2006 Sonic Blue ZXW
Points 559, Level 11
Points: 559, Level: 11 Points: 559, Level: 11 Points: 559, Level: 11
Level Up 18% Completed
FF Reputation: 1 clayton89 Good Standing Member
Originally Posted by rambleon84 View Post
Call a couple of Ford dealers and ask if that's something they can do. I had a conversation with a member a couple years ago that said their dealer was able to do it for less than $100 and the dealer's only caveat was they kept the old cluster.
Now, I dont recall if his new cluster had more or less miles. Not sure if its something they can only add miles to vs take miles off or vice-versa.
Found a couple on ebay with closer mileage for you:
128k (you'd need to contact them to verify it has tach)
The two most common parts numbers are:
one should be with tach and other without iirc but ebay sellers arent consistently labeling them the same. I bought a tach cluster with a couple of thousand more miles than my car had and swapped them over when the mileage matched. I did test it as soon as I received to ensure needles and lights worked properly. Very easy to do yourself.
I was just checking here to post that I had purchased one with 130K on it, it so happens to be the one you picked out before I even read your post.
clayton89 is offline
