Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Key without buttons
Old 01-15-2013, 01:23 PM   #9
cobie56
Fan#: 84403
What I Drive: '01 ZX3, '14 Civic XL '12 SEL
FF Reputation: 2 cobie56 Good Standing Member
Originally Posted by lddavis View Post
It's perhaps more important for the key to lock the steering than simply to serve as an ignition switch. You could hot-wire the ignition and drive off. That's why they started locking the steering column in the first place. And that probably means the lock has to physically be part of that mechanism.
All of which just means that designers ought to make sure you can see and easily reach the spot on the column where the key goes, without it being blocked by the wheel (airbag and all).
GM and other makes w/ the ignition key on the dash and not the steering column still have a locking steering wheel.. so the placement of the ignition switch on the column is not an issue.
cobie56 is offline
