Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Suspension Upgrade
Old 01-15-2013, 01:13 PM   #12
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by Bliky View Post
Since you're apparently the guru would this be the best setup for suspension performance? Why is this better than coilovers? Be technical, I'm curious :P
Also, how would I go about buying either if the dampers or shocks? Is there anything else I need?
I wouldn't say I'm a guru. I just have more practical experience than most in the MK3 area of the forum.
The reason I suggest staying away from coils is due to the area you live in. As a fellow member who lives in the northeast, coilovers are not a good bet for a daily driven car. I don't say that because the ride will be rough, but I say that because the salt, sand, brine, and other de-icing agents used on our roadways wreak havoc on suspension components.
I've had coilovers on past vehicles. Both times, the threads seized, rendering the ability to adjust the ride height useless, despite my best efforts to keep them oiled, lubed, and free of salt, sand, or other corrosive material. If you're after street performance, a good set of dampers paired with a set of reputable performance springs will be your best bet for durability, handling, and ride compliance. Pro-kits are fine. Steeda's springs might be better, but I can't vouch for that. I will say that the handling of my car with the Prokit springs, ST struts, and Koni rear shocks with the Steeda rear sway was phenomenal for backroad driving.
For the dampers, call up Tousley Ford and ask for Steve.
- AD-1098 F Upper Strut Mounts
- AST-12281 LH F Strut (ST-version)
- AST-12287 RH F Strut (ST-version)
- AD-1094 F Strut Bearings
Koni Yellows:
- 8040-1353SPORT Rear shock, adjustable, Mazdaspeed3
Here's how my car sat:
Yours will sit a hair lower, simply because the Titanium is a little heavier.
Joined the dark side.
Zillon is offline
