Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Suspension Upgrade
Old 01-15-2013, 12:56 PM   #11
Bliky
Bliky's Avatar
Fan#: 95135
What I Drive: 2012 Sterling Gray Focus Titanium
Points 4,033, Level 40
Points: 4,033, Level: 40 Points: 4,033, Level: 40 Points: 4,033, Level: 40
Level Up 42% Completed
Level up: 42% Level up: 42% Level up: 42%
FF Reputation: 5 Bliky Good Standing Member
Originally Posted by Zillon View Post
Whatever springs you do go with, choose ones that are linear and not progressive. They'll handle better, handle more consistently, ride better, and if you're pairing with your stock dampers, your dampers will last longer.
The Steeda springs are good springs. I'd strongly recommend pairing them with the OEM ST front dampers and Koni yellow rear shocks.
Since you're apparently the guru would this be the best setup for suspension performance? Why is this better than coilovers? Be technical, I'm curious :P
Also, how would I go about buying either if the dampers or shocks? Is there anything else I need?
'12 Sterling Grey Titanium Hatch - Moonroof / Winter Package / DCT / 17' Alloy Wheels
MK3 Manual Transmission Swap: http://bit.ly/1ondtuV
Bliky is offline
