Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT with sudden rough idle, power loss
Old 01-15-2013, 10:59 AM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,322, Level 100
Points: 33,322, Level: 100 Points: 33,322, Level: 100 Points: 33,322, Level: 100
Forum Activity 38%
In the future, listen for the fuel pump to buzz. On a Ford, if it doesn't buzz, that doesn't mean that the fuel pump is out- there is still the fuel cutoff, and the fuel pump module. About 90% of the time when it doesn't buzz when you turn the key to ON, that is the fuel pump.
Change that fuel filter every 25-30k miles, and if rust and abuse is a problem up there in WI, then use nickel anti-seize under the bracket, and on the threads of the bolt that holds the bracket down. It's messy, but it works. I buy this stuff by the bottle. It's a lot cheaper than purchasing those $1 tubes. It separates due to temp changes and non-use, but just stir it with a screwdriver- no harm done.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
