Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Looking for opinions on how to further improve handling
Old 01-15-2013, 09:34 AM   #10
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 4,066, Level 40
Points: 4,066, Level: 40 Points: 4,066, Level: 40 Points: 4,066, Level: 40
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
FF Reputation: 23 wrc_fan Great Standing Member
Originally Posted by mj22 View Post
Hey
If I go with the front camber plates should I look at getting the necessary items for rear camber adjustment and toe adjustment?
Thanks
Install the plates and get an alignment to see where the rear is at. Rear toe has a little bit of adjustment from the factory, for most cases, you want this at zero. If the rear camber is between -.5 to -1.5 degrees at each side, I'd leave it at that and call it good. If you have more than a 1.5 degree negative, you may want to add the camber arms.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
