Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Am i missing something??? Double din
Old 01-15-2013, 09:21 AM   #6
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,800, Level 44
Points: 4,800, Level: 44 Points: 4,800, Level: 44 Points: 4,800, Level: 44
Level Up 25% Completed
the first link with the second plug with the rca's on it is for if you have the factory sub so that you can retain it. the second one doesn't have the sub connector included. neither of those will retain sync (that's a special harness with a module on it.
here's the issue you will have with either of those kits. there is no accesory power in the factory harness on the 08-11 focus. with either of those you will need to run an acc wire to somewhere else in the car such as the ignition harness. there are harnesses made that will take the factory data signal and give you an acc output and another harness that will allow you to retain sync as long as the aftermarket headunit has an aux input on it (preferably on the back).
here's the one to retain sync
http://metraonline.com/part/AFSI-02
i can't find the other one at the moment, they may not make it anymore.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
