Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Looking for opinions on how to further improve handling
Old 01-14-2013, 01:08 PM   #7
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
Stay away from adjustable control arms, especially if you plan on running anything wider than a 7" wheel with sticky rubber.
The problem is when you add camber this way you lose clearance at the inside and top of your wheels.
Get yourself some good camber plates, KMAC is based in Australia I believe, those are a MUCH better solution because you change the angle of the entire strut assembly.
Also, as was somewhat mentioned above your sway bars are probably way too thick for the spring rates of those SPAX components. Does the car have a propensity to understeer or oversteer currently? Will it rotate quickly? Is it unstable at high speed? What kind of surface conditions do you normally see?
Just throwing big bars at the car won't make it handle well, especially with soft springs.
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
