Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Finally Working!!!
Old 01-14-2013, 06:09 AM   #6
hockeydoc33
hockeydoc33's Avatar
Fan#: 90937
What I Drive: 2003 Screaming Yellow SVT
Points 466, Level 9
Points: 466, Level: 9 Points: 466, Level: 9 Points: 466, Level: 9
Level Up 32% Completed
FF Reputation: 1 hockeydoc33 Good Standing Member
Originally Posted by beatmaniac1 View Post
Damn ! I just have been through positivevibez thread and I was discouraged by all it took him to get is car right . I bought a svtf a month ago and I already have encountered a couple of problems that were not existent when I test drove the car clutch is beginning to slip, thermostat housing had to be changed, tranny starts to grind a bit when shifting, had ignition problems and the motor seems to burn oil. I was told by another member local forum member who went to buy the car that the it ran low on oil so i'm now getting paranoid for every sound that might be coming front the front of the car. I'll get the car into a garage to make a compression test and oil change-up, is there anything else that I can inspect to determine whether or not the motor has suffered from mistreatment ?
It as around 250K km on it so I dont expect great compression numbers , but what would be good compression numbers from a svt ? Apart from the 10% max between cylinders.. And is there a way to know if the bearings are toasted ? (beside the knocking sound they produce when it's too late )
Thanks for the replies !! This side of the border, nobody seems to know about the svtf's
Well my issue was much different then your's. If I have one suggestion for you is if you have any issues with the engine and tranny I suggest you get a junk yard engine.
In total I spent $7,500 to get my car fixed. Doubled my cost of buying it. Totally worth it and I will drive it into the ground but you're looking at a lot of serious issues that makes your car not nearly as reliable and performance will be slacking.
As far as inspecting your engine. Open up the Cam Belt cover and inspect the belt. I dont know if you know but this is an Interference engine, look that up if you don't know about it, so make sure that belt has been replaced on it. Other things to check is the spark plug wires/plugs and catalytic converter.
When this car is running right it is quick and smooth. Not many 4 cylinder cars can be shifted at 2000 RPM and feel like a V6 accelerating off the line.
Best of luck!
hockeydoc33 is offline
