Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is something broken with my heater?
Old 01-14-2013, 02:03 AM   #4
elsolo
elsolo's Avatar
Fan#: 96835
What I Drive: 2007 white ZX3
Points 2,941, Level 33
Points: 2,941, Level: 33 Points: 2,941, Level: 33 Points: 2,941, Level: 33
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
Forum Activity 7%
FF Reputation: 18 elsolo Great Standing Member
I haven't touched an '08, but it's simple on a 04 and probably the same:
-Three small screws that hold the glovebox door on at the bottom.
-Three phillips head pushpins that hold the cloth/padded trim under the glovebox
-One screw that holds a small airduct to the blower motor, plainly visible with glovebox door removed.
-Three screws that hold the blower in, they go straight up/down
-One electrical connector to the blower motor
Once the blower motor is out, the black plastic cover is removable if you push in the three rubber detent tabs, it pops off exposing the motor armature and brushes.
It will probably take you 15-30 minutes to take apart the first time. You just need small hexdrivers or socket set for the small screws, they are hex head. phillips screwdriver for the push pins, and I needed to use three small acrewdrivers/picks/whatever at the same time to push in the detents on the motor cover.
elsolo is online now
