Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fog Light Installation - S Model (with Pics)
Old 01-13-2013, 07:55 PM   #73
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by Chaddz3 View Post
LED's don't draw nearly as much power as incandescent bulbs do, so splicing an LED strip in the parking light circuit shouldn't be a problem.. just make sure to solder the splice so it doesn't corrode from being exposed to the elements, and if you can find it, use meltable wall shrink sleeving on the splice to seal it good. Something like ES2000 sleeving if you can find it. Meltable wall sleeving is basically shrink tubing with a layer of hot glue inside that seals exposed copper so it can't corrode.
Yeah I know to solder and shrink-wrap ;)
Just want to do a little something to the covers until I can come up with the patience and money to do the full fogs. Then tackle the HIDs and projectors.
Thanks for the quick response Chad.
thejordan is offline
