Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Power Steering Fluid is Foaming
Old 01-13-2013, 03:22 PM   #4
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
If your fluid is low or dirty do the above recommended with the turkey baster. This is the lazy way to change fluid, I did it on my girlfriends saturn.
I sucked as much as I could out, topped it off with clean fluid had her turn back and forth (front of vehicle jacked up, engine running), repeated until fluid was 90% clear which took about 2 quarts. I would assume you would have it mostly clean after a gallon
You'll never get it all unless you do an actual flush though.
A7xschecter6661 is offline
