Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 04 Zetec belt screeching
Old 01-12-2013, 09:32 PM
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,430, Level 29
Points: 2,430, Level: 29 Points: 2,430, Level: 29 Points: 2,430, Level: 29
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 7%
Buy-Sell-Trade Rating: (3)
Check the accessory (serpentine) belt tensioner for correct operation. They sometimes seize or lose the ability to apply proper spring tension to the belt. Your accessory belt likely needs replacement if it's old or has been slipping for a while.
Belt squeal on start up is usually the belt slipping on the idler/drive pulleys. It can also be the idler pulley bearing failing. Curing the problem simply involves replacing the affected parts.
BC_ZX3 is offline
