Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Have you ever noticed this when you are low on fuel??
Old 01-12-2013, 06:13 PM
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,308, Level 72
Points: 12,308, Level: 72 Points: 12,308, Level: 72 Points: 12,308, Level: 72
Level Up 65% Completed
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
Buy-Sell-Trade Rating: (3)
Originally Posted by dpando1 View Post
I have a little over 10,000 city miles on this car. because it's direct injection I am sure that it could use this ATLEAST for cleaning the intake valves and injectors...But yeah any extra information would help.. I am on there site right now...I definitely want to get to the bottom of this
thanks for everything btw
Anything you put in the gas tank won't ever clean the intake valves unless you have fuel and air leaking out of the cylinder back into the manifold with these cars.
Direct fuel injection means there is no air/fuel mixture inside the intake manifold, only air and a bit of exhaust gasses that are recirculated pass through the intake into the cylinder. Fuel is injected directly into the cylinder itself at high pressure.
This was one of the key enablers for the 12:1 compression ratio to run on 87 octane fuel without the increased risk of pre-ignition or spark knock in a SI (spark ignition) engine.
suss6052 is online now
