Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - AppLink Available on 2013
Old 01-12-2013, 11:36 AM   #64
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Initially they kept claiming it was coming and that the engineers are working on it, but somehow unless they changed the modules completely to something that is not compatible in the 2012 it should just be a software patch away but they won't let us even try it.
Man, I figured if anyone knew of any hardware/module changes it would be you suss. You seem to have a really good handle on this stuff. I kind of get the feeling there must be because if it were all the same, like you said, a simple software patch/update. Should be a no-brainer if the hardware is truly the same.
Regardless, often times silence actually says a lot more than words.
Seems there is similar sentiment going on at the Explorer forum as well (last few posts):
http://www.explorerforum.com/forums/...=312673&page=5
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
