Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - crappy fuel mileage
Old 01-12-2013, 09:54 AM   #44
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 13,684, Level 76
Points: 13,684, Level: 76 Points: 13,684, Level: 76 Points: 13,684, Level: 76
Level Up 9% Completed
Forum Activity 99%
FF Reputation: 18 Magus2727 Great Standing Member
Originally Posted by gonefhsn View Post
This is not correct, the engine can be at bottom dead center and the cams can be locked. That is why it is always best to use the timing set when doing the timing belt this way you will be sure that you are at TDC because the crank pin only fits when at TDC.
I am sorry yes the cams can be locked in both conditions. However you could change the timing belt when locked in TDC or bottom dead center can it not?
Magus2727 is offline
