Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - crappy fuel mileage
Old 01-12-2013, 06:00 AM   #42
gonefhsn
BEWST AGAIN YAY!!!!!
gonefhsn's Avatar
Fan#: 45759
What I Drive: 13 Tangerine Scream ST2,12 RAM 2500
Points 96,869, Level 100
Points: 96,869, Level: 100 Points: 96,869, Level: 100 Points: 96,869, Level: 100
FF Reputation: 21 gonefhsn Great Standing Member
Originally Posted by Magus2727 View Post
the gears can only be locked when the motor is in Top Dead Center.
This is not correct, the engine can be at bottom dead center and the cams can be locked. That is why it is always best to use the timing set when doing the timing belt this way you will be sure that you are at TDC because the crank pin only fits when at TDC.
gonefhsn is offline
