Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lost Keys (2001 SE)
Old 01-12-2013, 12:04 AM   #14
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 558, Level 11
Points: 558, Level: 11 Points: 558, Level: 11 Points: 558, Level: 11
Level Up 16% Completed
Forum Activity 3%
FF Reputation: 25 Milton Great Standing Member
PATS Master Key vs Clone key
Originally Posted by amc49 View Post
Milton, I could find nothing in that 10th post, maybe I'm blind. Regardless, I was speaking obviously off the cuff rather than out of knowledge........
Hey no problem, sometimes the whole PATS system can be confusing, People think that if they have 2 working keys that guarantees that they can introduce a third key and then they do not understand why that is not a guarantee. When I got my 2007 Focus it came with one master key and a clone of that master. When the clone key started failing I was forced to learn how the PATS keys work. Here is the information that provides a basic understanding of the PATS system:
A PATS key has an RFID chip embeded in the handle. When you insert the key into the ignition the computer reads the chip and if it's ID matches one of up to six IDs stored in it's memory your computer will work with it. If the cut pattern of the key matches the cyclinder then you can rotate the ignition switch and all works. If the chip does not match one of the 6 stored IDs, or if the computer is unable to read the key's chip, your computer will not start the car even if the key rotates the ignition switch. So even if your new key does have a PATS chip, if it is not paired with you car's computer so it will not work.
There are a couple of ways a locksmith can make a key for you:
DEFINITION: A "Master Key" is just a key whose ID has been paired (accepted and stored) into your car's computer.
1) Clone a master key: The key blank for these have an even fatter handle and do not have a FORD logo. After the locksmith cuts the teeth pattern, they read the ID from a "known working" key and write it to the newly cut key, hence you have a clone of the original key. In my experience these clones stop working in a couple of years. Also as far as your PATS system is concerned this cloned key does not count as a second master key. Some clones have a battery that requires replacing.
2) Make a new master key: A new OEM blank is used, and it's chip already has an unchangable ID. The locksmith cuts the teeth and the key's ID is paired to your car's computer.
3) Pairing a new master: If you have two master keys (not a master and it's clone) you can pair it yourself. If you do not then the locksmith can connect a computer to your car and pair the new key in about 10 minutes.
I went through all of this on my Focus when the cloned master died. In the San Antonio area it cost me about $35 for a locksmith to create a new master from an OEM blank and pair it to my car.
Milton is offline
