Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - crappy fuel mileage
Old 01-11-2013, 05:12 PM   #34
PWGuy
Fan#: 91777
What I Drive: 2003 Pitch Black ZTS Sedan
Points 2,426, Level 29
Points: 2,426, Level: 29 Points: 2,426, Level: 29 Points: 2,426, Level: 29
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
FF Reputation: 1 PWGuy Good Standing Member
Originally Posted by Top-Ace View Post
I am having the EXACT same problem with my Zetec ZTS. I have replaced plugs, wires, coil pack, fuel filter, air filter, pcv valve and hose, oxygen sensor, DPFE sensor, EGR solenoid, probably more I cant remember. I have a Snap-On Solus scanner and do not see any problems. Fuel trim is at a rock solid plus or minus 2, so no vacuum leak.
It is also stumbling when very cold at start up. Also less power going up hills.
I am getting around 24-25 maximum MPG all long distance highway, much worse in city. Honsetly at this point, I think the timing is slightly off. Maybe the exaust side cam timing is off a few degrees, which i know can cause these symptoms.
So changing the timing belt will fix this or is more required to fix, if it's an exhaust side cam timing issue?
PWGuy is offline
