Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dogbone install issues need help ASAP
Old 01-10-2013, 05:49 PM   #13
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 MX-5 and 09 Focus Coupe
Points 14,780, Level 78
Points: 14,780, Level: 78 Points: 14,780, Level: 78 Points: 14,780, Level: 78
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 12%
Activity: 12% Activity: 12% Activity: 12%
FF Reputation: 30 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (50)
Put your car on either jackstands or ramps. Take your jack with a block of wood on the lip and place that under your car. Raise the jack until it is supporting the motor. Loosen up the passenger side motor mount but don't take the bolts all the way out. This will give you a bit more of swaying motion in the motor. You may need someone to hold the engine while you place the dogbone mount into position. After you get the mount into position put the bolt in there and then tight the passenger mount back down.
zetecDon is offline
