Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - pain in the arse just for a headlight
Old 01-10-2013, 01:44 PM   #5
fresh1dougie
fresh1dougie's Avatar
Fan#: 21165
What I Drive: 2005 Sangria Red ZX3 SES Auto 2.0
FF Reputation: 1 fresh1dougie Good Standing Member
Slow down
First remove the circular black rubber cover on the back of the housing assy. Pinch the little release lever carefully on the wiring harness and pull back and lay aside for the moment. In this opening you will find a black plastic locking ring. Carefully twist it off. (visually note the orientation of the ring), next remove the bulb assy. Reverse these steps to install. A little dab of dielectric on the contacts may prevent future corrosion. These parts are brittle plastic so be patient as not to break anything, they break easily. The right headlight assy can be tricky, as the battery is located right behind the opening.But it can be done. Estimate 30 mins job time total for both. Good luck.
fresh1dougie is offline
