Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - H&R Front sway bar too much?
Old 01-10-2013, 01:22 PM   #6
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 9,732, Level 66
Points: 9,732, Level: 66 Points: 9,732, Level: 66 Points: 9,732, Level: 66
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
Forum Activity 44%
Activity: 44% Activity: 44% Activity: 44%
Buy-Sell-Trade Rating: (15)
Originally Posted by PSUrivie View Post
yeah, I thinking it'll give me a little more handling. However, I'm not sure if it will hinder the handling characteristics than improve them.
Well how neutral is your handling now? Are you looking for more neutral, under/oversteer? If you have too much oversteer, then a larger front bar can help but might cause too much understeer if its too big tricky
Unless some one chimes in and says they have gone through both setups (along with the gaz/rs spring combo) that you are talking about and it was much improved, I'd say to pass on it. If it was as easy of an install as a rear sway bar, there would be no discussion needed as you would easily just swap one out and compare. Front sway bar is a pita to do, so if you dont like the results, you'd have to go through that process again. Unless you have access to a garage/lift, air tools and can get the work done easily.
It may be worth it if it does make an improvement but for me, I'd have a hard time justifying it for normal street use. If you start racing and need to fine tune your handling, then it might be something to try out.
rambleon84 is offline
