Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Trading in foci at 30,000 miles??
Old 01-10-2013, 12:29 PM   #37
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
Points 367, Level 7
Points: 367, Level: 7 Points: 367, Level: 7 Points: 367, Level: 7
Level Up 34% Completed
FF Reputation: 3 flyboyike Good Standing Member
If its at 3400 rpm that's again nearly 400+ rpm more than it would be if it had a 6th gear.
Is it strictly necessary to have the 6th gear? No, the fifth gear will still top out at a higher top speed than the car is capable of reaching due to the speed limiter/ governor.
I don't want to say no one should buy the 5MT, in fact I very nearly did except for the fact that I couldn't get what I wanted with the manual at the time.
If Ford was commited to "one Ford" we shouldn't have to choose between equipment or transmission choices. My exact same car would have been available in Canada with the 5MT, but even though they were all built on the same assembly line they would not allow you to custom order it with a manual.
Even if I wanted to I couldn't get it as an SE instead with the sport package as they had restricted the interior trim options against it, even though the Escape is the exact opposite, you can't get this color with the light interior instead of the dark one in the Escape. You can even get it in a Titanium which you could not with the Focus for the same reasons.
For the type of driving I had been doing the extra gear on the freeway would be great.
80 MPH with the taller gear is just under 3000 rpm (2953 rpm) with the taller 6th gear and marginally shorter final drive.
The clutch of the five speed felt really good, much the same as my old car, but the shifter was a touch vague, and not quite as smooth as the MMT6 in the ST.
I was more concerned with the ambient noise at higher speeds, as well as the fuel efficiency gains to offset the weight gain over the older car. At speed on the freeway the inertia helps, but around town the car will suffer more off of the line.
I like driving a manual, but you can thank/ curse Ford for not offering more choices.
Look, suss, we get that you went with an auto, and more power to you, but give it a rest already with the sixth gear bit, it's getting boring.
flyboyike is offline
