Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - FSWerks Cool-Flo Intake Installation Problems
Old 01-09-2013, 07:43 PM   #83
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 9,624, Level 65
Points: 9,624, Level: 65 Points: 9,624, Level: 65 Points: 9,624, Level: 65
Level Up 92% Completed
Forum Activity 6%
FF Reputation: 10 crice8 Great Standing Member
Buy-Sell-Trade Rating: (14)
That whistle you hear is a leak of some sort. check those two hoses that connect to the intake. After you tighten up the hoses unplug your negative battery cable for about 10 mins then reconnect it. This will reset the ecu. start the car and let it idle for about 10 mins then take it for a ride around the block. see if it is still making the weird noises. If so wait it out as you drive 50 miles over the next day or two and see if it continues. the pcm needs to readjust to the intake and it takes a little time to do it.
Galatians 6:14
crice8 is offline
