Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2000 zx3 won't idle, sometimes
Old 01-09-2013, 03:17 AM   #1
Fan#: 108115
What I Drive: 2000 White ZS3
FF Reputation: 1 FocusGroupy Good Standing Member
My daughters 2000 ZX3 runs fine most of the time. But occasionally, after being driven for a while and shut off and restarted it will not idle and die. You can keep it running by applying a little pressure to the gas peddle. If you wait about 45 min to an hour usually it will run normally again.
It seems totally random. sometimes it will not do it for weeks or months (the longer times between events are in the winter).
My scanner can only read codes, it can't read things like fuel pressure and real time data. No Codes are set.
Any ideas?
FocusGroupy is offline
