Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Snorkel Delete
Thread: Snorkel Delete
Old 01-09-2013, 12:40 AM   #153
Fan#: 92144
What I Drive: 2012, Grey, Focus SE Sport Package
Points 225, Level 4
Points: 225, Level: 4 Points: 225, Level: 4 Points: 225, Level: 4
Level Up 50% Completed
FF Reputation: 2 dpando1 Good Standing Member
Originally Posted by TiStick View Post
His CA 91 isn't much better then our 89, if at all.
+1 on the owners manual part:
Octane recommendations
Your vehicle is designed to use “Regular” unleaded gasoline with a pump (R+M)/2 octane rating of 87. Some stations offer fuels posted as
“Regular” with an octane rating below 87, particularly in high altitude areas. Fuels with octane levels below 87 are not recommended.
Premium fuel will provide improved performance.
12:1 would be an incredibly high compression ratio on 87 octane if it wasn't for the Gasoline Direct Injection and the twin independnt variable camshaft timing.
The injection of liquid fuel directly into the cylinder cools the compressed air charge and helps to prevent detonation, as well as the variable cam timing retarding the combustion cycle enough to prevent spark knock for the most part. It does this by sacrificing a measure of power and performance that could be gained with advanced spark timing. 91-93 octane fuels are more resistant to pinging and detonation/ pre-ignition and therefore the car can adjust timing accordingly in order to make more power from the same quantity of fuel consumed.
So filling up with a premium fuel would actually improve performance? Meaning the car knows it has premium fuel and adjusts for it?
dpando1 is offline
