Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - positive camber after installing coil overs
Old 01-08-2013, 10:53 PM   #6
israel's Avatar
Fan#: 102083
What I Drive: 2004 svt focus
FF Reputation: 1 israel Good Standing Member
Originally Posted by sleepyboy View Post
How much positive camber do you have? Do you have an alignment sheet from the alignment? Did you replace your sway bar links as well at the same time? Those are known to cause the popping noise though wouldn't have anything to do with the positive camber issue. Does it have upper camber plates on the coil overs? If not then I would try those out to dial it in where it needs to be, that's if everything was installed correctly.
its not too much of positive camber but i can tell there is some, yea sway bar link and ball joints were replaced at the time the coilovers were installed, umm no i bought them used n didn't come with that....could that b the problem?
israel is offline
