Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - positive camber after installing coil overs
Old 01-08-2013, 09:35 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
What I Drive: 01' Yellow ZX3 euro, 04' ZX5 SVT
Points 159,089, Level 100
Points: 159,089, Level: 100 Points: 159,089, Level: 100 Points: 159,089, Level: 100
Forum Activity 5%
FF Reputation: 51 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
How much positive camber do you have? Do you have an alignment sheet from the alignment? Did you replace your sway bar links as well at the same time? Those are known to cause the popping noise though wouldn't have anything to do with the positive camber issue. Does it have upper camber plates on the coil overs? If not then I would try those out to dial it in where it needs to be, that's if everything was installed correctly.
I started out with nothing and I still have most of it left
Hatch Nation #15 (Ole' Yeller') & #150 (The SVT)
Moderator for
sleepyboy is offline
