Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Retrofit AGS (Kysor Active Grille Radiator Shutters)
Old 01-08-2013, 07:39 PM   #19
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,333, Level 72
Points: 12,333, Level: 72 Points: 12,333, Level: 72 Points: 12,333, Level: 72
Level Up 71% Completed
Forum Activity 5%
Buy-Sell-Trade Rating: (3)
Originally Posted by feta_mgp View Post
I recall just fine how they were rated and I'm sure that if you DROVE in SelectShift all the time your mileage would suffer, justifying the lower number. However the gearing and transmission are the same... adding a feature that allows the driver more precise control isn't going to cause any difference unless the feature is used. Don't use SelectShift, don't affect mileage.
If you only used the automatic sport mode all the time your mileage could suffer due to locking the car out of 6th gear, but if you know how to drive a manual and shift gears already your mileage would actually improve or at worst stay the same. However per the test conditions they had to shift through certain gears at a given time which is counter to the car being left in automatic mode alone.
suss6052 is offline
