Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - crappy fuel mileage
Old 01-07-2013, 08:52 AM   #10
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,103, Level 77
Points: 14,103, Level: 77 Points: 14,103, Level: 77 Points: 14,103, Level: 77
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
Forum Activity 24%
Activity: 24% Activity: 24% Activity: 24%
you use the same station, same pump, and let it auto kick off with out topping off?
going from 250 miles and putting in 11 gallons vs 250 and putting in 12 gallons is a difference between 22.72 and 20.8 basically a 2 MPG drop because you put a little more or less fuel on each fill up.
If you saw that much of a change in your fuel economy from going from a 89 to a 93 octane (my altitude I live has offset octane levels, 89 is still a mid grade right? what were you getting on 87?) then something is wrong. the motor it self does not run any differently as it can not tell the octane nor is it tuned to advance timing to make use of higher octane. So the only reason why you would see better fuel economy is that the octane is "fixing" another problem.
What could cause this? I am not sure. Another thing to note is that most fuels have detergents in them, some more than others. you can typical get better fuel economy from Costco gas because they typically have less additives like the Chevron or Shell gas.
Magus2727 is offline
