Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Iac valve
Thread: Iac valve
Old 01-06-2013, 05:50 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,118, Level 77
Points: 14,118, Level: 77 Points: 14,118, Level: 77 Points: 14,118, Level: 77
Level Up 17% Completed
Level up: 17% Level up: 17% Level up: 17%
Forum Activity 36%
Activity: 36% Activity: 36% Activity: 36%
Its on the intake manifold. back side about middle. Below the TB and when installed on the motor above the starter. Its a PITA to get to but I have found its best to go from the bottom. you have to do most of it by feel and don't have a whole lot of room to swing wrenches so is a little slow going to back out the I believe 10mm (two) bolts.
Their is a write up IIRC on the cleaning of this. think you basically just use Carb cleaner and some Que tips and let it dry then re-install. hardest part is putting the gasket back on since you cant really see what your doing.
Magus2727 is online now
