Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil in Cylinders, Failing to cold start
Old 01-06-2013, 05:30 PM   #5
amc49
Fan#: 96610
Points 6,688, Level 53
Points: 6,688, Level: 53 Points: 6,688, Level: 53 Points: 6,688, Level: 53
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
Forum Activity 100%
On anything with spark plug tunnels I ALWAYS look inside before removing plugs. If enough oil or water in there, when it runs in after you yank the plug, there could be enough fluid in cylinder to hydrolock and break or bend a rod. Any dirt in tunnel also swept in by the oil. I generally blow out the tunnels before yanking plug too, you'd be amazed what gets in there even with a normally covered top.
amc49 is offline
