Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil in Cylinders, Failing to cold start
Old 01-06-2013, 04:52 PM
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,648, Level 100
Points: 32,648, Level: 100 Points: 32,648, Level: 100 Points: 32,648, Level: 100
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
Yeah, your problem is going to be the valve cover gasket. Oil leaking in around the spark plugs from the bad gasket will seep up the coil boot and cause the spark to short out. I highly suggest that you get a new valve cover gasket before you end up KOing a coil. The coils are $90 each.
You might want to get some coil boots. Those cost $5-8 each, and are easy to replace. Mine went out about 80k miles.
The valve cover gasket is not hard to change. Don't be intimidated by not having an in-lb torque wrench. The valve cover has metal collars in the screw holes so the only way you will over tighten it is to be trying to break something. The most important thing about tightening down a new valve cover gasket is to be sure that you start tightening down from the center in an X shaped pattern to the outside edges. Never start at the outside working to the inside.
These gaskets are super easy to replace- it's a molded gasket that fits into a slot. Use a screwdriver to lightly pry up the old gasket, and pull it out, then press in the new gasket. That's all you have to do.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
