Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil in Cylinders, Failing to cold start
Old 01-06-2013, 04:45 PM   #3
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 8,913, Level 63
Points: 8,913, Level: 63 Points: 8,913, Level: 63 Points: 8,913, Level: 63
Level Up 55% Completed
Level up: 55% Level up: 55% Level up: 55%
FF Reputation: 17 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (11)
Are you sure your valve cover gasket isn't bad? Maybe when you removed the plugs the oil ran into the cylinders. If there was that much oil like you're saying you would be blowing blue smoke out of the exhaust.
I would do a compression test and pull the valve cover to inspect the valve cover gasket.
I do believe there is a TSB on the cold start issue. I think the fix was an update to the stock tune on the ECU.
FSWerks stg2 w/ water/meth; Cossie intake.
Massive Speed stg 2 cams in the works....
PSUrivie is online now
