Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Vibration
Thread: Vibration
Old 01-06-2013, 02:46 PM   #7
Fan#: 33469
What I Drive: 2000 black ZX3
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 FordZX32000 Good Standing Member
If the car is an automatic, it's easy to check motor mounts. Pop the hood, have someone sit in the car. Put the car in gear with one foot on the brake, and then give the engine gas. The engine will lurch if the motor mount is bad. You'll see more than 1" of movement. If it's ok, then you won't see much movement when you give the engine gas with a foot on the brake.
That's a good post and sounds like a real easy way to check them. Question, why are the vibrations so bad when the car is first cranked-cold "versus" after warm up ?
FordZX32000 is offline
