Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ATX shift kit
Thread: ATX shift kit
Old 01-06-2013, 06:23 AM   #1
Diesel's Avatar
Fan#: 86584
What I Drive: 99 zx2, 04 focus wife's car
Points 1,885, Level 25
Points: 1,885, Level: 25 Points: 1,885, Level: 25 Points: 1,885, Level: 25
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 2 Diesel Good Standing Member
ATX shift kit
I've seen complaints on here and else where about the 4f27e (1st gen focus axt) having low line pressure. well I found a kit that replacs a spring and ups the pressure. I'd seen a performance shop ups the pressure by about 5%
Has anyone done this to theirs?
Here is a kit I found: (this isn't an ad I'm looking for others advive. Won't let me copy pic.)
Shift Correction Package
This valve body kit deals with these problems:
* Soft shifts and flairs
* Premature band failure
* Code P0741 (T.C.C. slippage)
* Broken solenoid P.R. valve spring
* Worn or damaged accumulator bores
* Accumulator Buddy "Tool" Included
* Newly designed accumulator pistons included
The 4F27E kit includes Superior's patent pending billet 1-2 and neutral/ drive dual sealing ring accumulator pistons. This kit also contains one of our patent pending Accumulator Buddy brushes so no other tools or fixtures are required. The pistons and brush allow you to reuse previously discarded cases that would not have sealed due to premature ware. The 4F27E kit also includes a new, stronger solenoid pressure regulator valve spring to replace the frequently broken stock spring.
Rims, fog light conversion, Interrior lighting recolor from starfuryt
Diesel is offline
