Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Stability Control
Old 01-05-2013, 11:45 PM   #8
MetalMuffins
MetalMuffins's Avatar
Fan#: 107135
What I Drive: 2000 Mazda MX5
Points 1,220, Level 19
Points: 1,220, Level: 19 Points: 1,220, Level: 19 Points: 1,220, Level: 19
Level Up 20% Completed
FF Reputation: 4 MetalMuffins Good Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by MetalMuffins View Post
Well I got some supplies the other day and managed to get a switch wired up to disable the TCS, ESC, and ABS. If you read one of my earlier posts in this thread, I have went over the effects of pulling the F19 5A fuse when driving. This is a short how-to if you want to wire up your own.
Sorry I did not take any pictures when installing, so these are all taken after the install was completed.
The switch is a simple on/off rocker switch. This must be wired into the fuse box via two wires that will run to the engine compartment through the fender. This I found was the easiest way to run the wires without modifying the car.
The switch is zip-tied to the wire running into the ambient lighting under the foot-well. This lets the rocker switch fit in between the kick panel on the side and the heat vent. It is very out of the way and won't be kicked.
The switch is wired as follows. I wish I had taken a picture of how the switch was wired before installing, as this is the most confusing part of the install.
1) The first wire from the fuse box must be connected to the switch
2) Make a very short wire with two female spade connectors, this will run from the other pole of the switch to the 5A fuse that is zip tied to the side of the switch.
3) Connect the female spade connector on the second wire running back to the fuse box.
This is a picture showing the cabin where the wires are running through the fender. You can push the wires right into the engine compartment and around the back of the fuse box.
This picture shows the inside of the fuse box where the wires run into the box. You do not have to modify anything, but I recommend pushing the wires through from inside the fuse box. You have to remove the plug for the fuse box to do this, but can be done easily by lifting the blue lever. Note the is a small black tab that must be pushed aside to lift the lever.
You can remove the plastic holder for the three fuses that control the TCS/ESC and install the two main fuses by themselves.
I connected the wires to the F19 fuse connector with male spade connectors. You can cut them in half with strong wire cutters and file them smooth. This makes them the same size as ATM fuse prongs. You can see the hole where the wires run in the picture above.
The picture below shows everything closed up. You can see the wires running into the fender. They run around the top of the fuse box and enter under the main harness plug. Again, I recommend running the wires from inside the fuse box and than around the top and through the fender to the interior.
I have tested this and it works like a charm. Once again, I wouldn't recommend leaving the track control off for normal driving, and I feel the system does an OK job, but this will allow you to turn it off easily if you want / need to in a pinch.
Please let me know if you have any questions, and you can view all of the pictures I took here: http://s1305.beta.photobucket.com/us...ffins/library/
Copy/Paste from this thread: How to turn off traction control? S model
Direct switch and no mods to the car itself, completely reversible. Cheers
Gone (But not forgotten) - 2013 HB MTX, Tux Black w/ Black Pack - Steeda RSB, Snorkel DLT, K&N Drop in, E-Focus RMM, Redline Tuning Hood Struts, Custom Al. Skid-plate, 180 Stat, Tune by Tom @ Focus-Power
Current - 2000 Mazda MX5
MetalMuffins is offline
