Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Continuous's Build Thread
Old 01-04-2013, 10:38 PM   #1
Continuous
Continuous's Avatar
Fan#: 84970
What I Drive: 2004 SVT ZX3 Infra-Red
Points 1,035, Level 17
Points: 1,035, Level: 17 Points: 1,035, Level: 17 Points: 1,035, Level: 17
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 Continuous Good Standing Member
Since I made one of these on Focal Jet I figured I'd start one on here as well.
So basically I've recently purchased a 2004 ZX3 SVT in Infra-red and I decided that I needed a build thread. Just to give you all some of my background I am a Ford Certified Service Technician so the work I'll be doing is somewhat easier becuase I have access to the manuals. That doesn't mean I won't share that information with any of my fellow Foci drivers just hit me up if you need the info. I setup my build lists by categories and I may need some of your help to decide which manufacturer to go with in some of the parts I purchase. Any of the parts I have options afterwards are where you my fellow Foci enthusiasts come in if you have an opinion on the choices let them be known. Now my car besides the wheels the car is completely stock. So here are my categories:
Interior
Ebay Hvac Knobs
http://www.ebay.com/itm/3pcs-White-A...item35be091afc
Shift Knob(not sure what one I want yet open to suggestions)
E Brake Handle(same as above)
Redline Accessories Shift and Ebrake Boots
CFM Adjustable Short Throw ShifterINSTALLED
Redline Tuning SVT Dead Pedal
Redline Tuning SVT Floor and Cargo Mats
Paneling under the carpet in my Trunk
Exterior
Plastidipping the Roof Black with GlossifierRECEIVED
Replacing GrilleINSTALLED
http://www.carid.com/2004-ford-focus...le-241499.html
Upgrading Headlight Bulbs(PIAA, Phillips, HOEN, or Hella)
Changing Fog Light bulbs to Nokya Yellows
Replacing Tail Light Bulbs with LED Bulbs
Long Reach Lugnuts
Replace Headlamps with Factory Lamps
Redling Tuning Hood Struts
Wheel Repaint or Powdercoating(Black or Silver)
Replacing the Tint with Black
Possibly adding an SVT Cobra Badge somewhere
Suspension
Sway Bars(Eibach or H&R)
Upper Front Stress Bar(Massive Massacre or FSWerks)
CFM Front Lower 2 Point Brace
Rear Upper Stress Bar(Massive Massacre or FSWerks)
Performance
TruBendz 2.5" Exhaust with Borla MufflerEN ROUTE
ORPBOTH RECEIVED ONE INSTALLED
Cold Air Intake(AEM or FSWerks)
CFM 67mm Throttle Body
Ignition Coil(Screamin' Demon or MSD)
Plug Wires
JBA Shorty Header
FSWerks Aluminum Lightweight Flywheel
FSWerks Crank Underdrive Pulley
VF Engine Mounts from FSWerks
How she looked as I bought her:
Then I Deleted the Lunchbox and attempted to hollow the cat was not so successful with the cat.
I received some late presents in the mail in the last couple days, yesterday I received this:
I just did a test fit and install of it today still will be removed and plastidipped black but doesn't look too bad, I will take some daylight pics though cause the lamps behind it aren't as visible in normal daylight.
And last but not least I received one of my two ORP's today as well as my Plastidip and Glossifier from Dipyourcar.com.
(Dogs can't keep their noses out of the way sometimes, this one will be for inspection purposes since we just have a visual inspection of emissions devices and this one looks like it has a cat in it yet.)
(This is for the Grille which is staying matte black and the rest is for my roof doing black then glossifier.)
Infra-Red SVT ZX3
Continuous is offline
