Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Lowered on H&R red race springs... anyone have camber wear?
Old 01-04-2013, 09:19 PM   #18
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,774, Level 95
Points: 24,774, Level: 95 Points: 24,774, Level: 95 Points: 24,774, Level: 95
Level Up 43% Completed
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
Originally Posted by thenorm View Post
you don't need to correct the camber as long as you have very little toe (1/16" toe out in front, zero toe rear)
I 2nd that. ^^^^^^^^^^^^ I like a tad bit of toe on the rear, as I tried the zero toe on the rear= it whips & you have to pay attention. To the OP, you should of done the alignment your self, since you work there. You can adjust it to where you wanted it & not just hit the green & ship it. I've done alignments for over 15yrs my self. Mine is at -2.0 degrees in the front & -1.5/-1.7 in the rear w/ the front toe at zero & 0.09/.010 rear toe in degree's. I also have CFM's tubular controls arms on the front for more camber. My tires are wearing evenly all the way around too. I have the Eibach sportline system which is 2''/2.2'' lower.
felixthecat is offline
