Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Shifting at what RPMs consistantly will start to hurt vehicle life?
Old 01-04-2013, 12:27 PM   #10
lddavis
Fan#: 104180
What I Drive: 1997 Red Outback
FF Reputation: 2 lddavis Good Standing Member
If you drive at 3000 rpm rather 2000 rpm at the same vehicle speed -- you're in the wrong gear.
Driving at constant speed doesn't require a lot of power, so you upshift to drop the RPM and cruise along for quiet and economy. When you want to accelerate, you downshift, and increase RPM, because higher RPM is generally more power. (The engine's peak power is usually not exactly at redline, but somewhere between a little to somewhat lower, depending on the design.) Once you've accelerated to where you want to be, you upshift again.
You don't drive around with a particular constant RPM as a target.
lddavis is offline
