Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Adding fog lamps?
Old 01-04-2013, 11:41 AM   #39
Fan#: 47691
What I Drive: 2013 Focus SE Hatch
Points 466, Level 9
Points: 466, Level: 9 Points: 466, Level: 9 Points: 466, Level: 9
Level Up 32% Completed
FF Reputation: 1 Monkeygrits Good Standing Member
Ok I started wiring. I hope someone can help me though. I need to know where to run the wire into the cabin for the switch from the relay which is out under the hood. Any help would be greatly appreciated. Heres where I mounted the relay. Its behind the fuse box on the bolt that holds the fuse box. I ran my ground for the relay and for the lights to the main gtound for the battery beside the relay in the pic. The green wire needs to go into the cabin. Its just laying up on the cowl in the pic.
After a little research I guess I may have to run the wire through the main harness grommet on the passenger side then run it back to the drivers side.
2013 Ruby Red Focus SE Hatch
2009 Vivid Red Mercury Mariner Premier
2003 Azure Blue Mustang Mach 1
Monkeygrits is offline
