Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Motor venting issue
Old 01-03-2013, 08:58 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,125, Level 77
Points: 14,125, Level: 77 Points: 14,125, Level: 77 Points: 14,125, Level: 77
Level Up 19% Completed
Level up: 19% Level up: 19% Level up: 19%
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
So you just have an oil line going to the PCV block off plate? and the valve cover going to a sealed can? That's not going to do anything. Not sure I understand what you mean by oil line. Usually you do the PCV delete if you have a turbo. Ideally what you will want is a air oil separator and tie the "outlet" to the intake to have a vacuum. it sounds like you have essentially completely sealed any venting of pressure and its finding its way out through the seals.
Pull all that off and put a breather on the Valve cover and put either the stock PCV on the motor or install an air-oil separator and install the "venting" of that to the intake to remove pressure.
Magus2727 is online now
