Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2003 cruise control shuts off
Old 01-03-2013, 08:06 PM   #44
Lscman
Fan#: 95211
What I Drive: 2007 ZX3 5spd, 2012 SE Sedan Auto
Points 1,639, Level 23
Points: 1,639, Level: 23 Points: 1,639, Level: 23 Points: 1,639, Level: 23
Level Up 39% Completed
Forum Activity 9%
FF Reputation: 9 Lscman Good Standing Member
Originally Posted by GreyScorpion View Post
I know the source, it comes back as: 0 Flashes (no flash after last button is pushed): suspect circuitry or speed control steering wheel switches. I guess I will start with getting a new set of steering wheel switches. I was asking if anyone knew how to remove the airbag but i will just research it. Thanks
All fuses are good
If you think the steering wheel switches are bad, they can be tested with an ohm meter using the wiring diagram. All they do is momentarily close or open and apply resistors between certain wires. You will need to disconnect plug coinnection at the column before checking impedance. It can't be done with the ckt normal. Keep in mind that the switches are connected to the cruise system through the trouble-prone clock spring assembly. I would be more suspicious of that flimsy thing.
Lscman is offline
