Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - frustration over power steering fluid
Old 01-03-2013, 07:38 PM   #22
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,454, Level 100
Points: 32,454, Level: 100 Points: 32,454, Level: 100 Points: 32,454, Level: 100
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
Originally Posted by Magus2727 View Post
Thought that the numbering is just the "version". Most systems if it calls for a previous Mercon the V (5) will work. Its backwards comparable. I think the Mercon V is the only type you can get now days anyway.
Is their any thoughts on running something like Royal Purple MAX ATF or similar full synthetic "performance" ATF fluid in the rack?
Nope, Mercon ATF is the transmission fluid labelled "ATF" or type F. It is exactly the same fluid as generic power steering fluid except that it has red dye in it, and used to be less expensive than generic PS fluid. I've been telling people who ask on this forum for years that you're better off using ATF than Mercon3 or 5. It might be backwards compatible in transmissions (IDK really), but it is not for PS pumps. What happens is that you develop that Ford PS groan. How'd I figure that out? A couple of lifetime warranty PS pumps, and a couple of gallons of Mercon3 until someone finally told me that was the wrong fluid to use. They were right.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
