Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2003 blaupunkt head unit no memory
Old 01-03-2013, 03:53 PM   #4
oderus1671
Fan#: 107936
What I Drive: 2003 silver 4 door focus
FF Reputation: 1 oderus1671 Good Standing Member
ok, so i recently noticed the clock is NOT keeping time. The fuse 31 is good, so it must have power all the time. I cant see how following the factory reset via pulling the fuse while playing a cd will help, as I can get to that setting normally just turning it on, and have already tried resetting it this way. Does doing the fuse-pull trick do something else other than doing it via the menu normally? It is not doing the reset over and over thing at all.
On a side note, the display also has vertical blank lines, or the so-called 'striped screen'. Could this be an indication of my problem?
I'd also really like to know what the fuse on the back of the head unit covers, the curiosity is killin me!It is red, and I think it is 5 or 10 amp.
I will try the fuse-pull thing tomorrow.
Just to clarify, this is the stock head unit that was factory installed and has never been removed, so I dont think any power leads got crossed.
Any suggestions? Im not in any shape to just buy a better aftermarket unit!
oderus1671 is offline
