Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZX3 Shift Cable Problems
Old 01-02-2013, 06:49 PM   #1
ryan8787
Fan#: 54045
What I Drive: 2001 Dark Blue ZX3
Points 735, Level 14
Points: 735, Level: 14 Points: 735, Level: 14 Points: 735, Level: 14
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 3%
FF Reputation: 1 ryan8787 Good Standing Member
I posted here about a month ago about my shift lever popping out of gear and being able to pop the bottom of the lever back into the shift cable to momentarily fix the problem. However, i have just been able to take the center counsel apart for the first time to get a good look at it. So it looks like the plastic round end of the shift cable is the weak spot in my problem.
So my question is, is there a way to switch out that plastic part, or would i have to completely replace the whole cable its self? I have looked around for a little bit, and it seems that the cables are replaceable without getting too much into it (only bending the heat shield a little to get the cable though the firewall and remove the air intake as well)
ryan8787 is offline
